- May 16, 2025
So long story short decided to book it in for it's m.o.t few days ago and took it out for its first drive on the road in about 20 years thought I'd take it out early and drag the breaks to clear them up as replaced them all a year ago with a new set all around and started to get a bit scabby.
took the car out and properly babying it as engine is completely fresh apart from a few start ups to bleed system . After driving for a few minutes I realised if I pushed the car a tiny bit like went over about 10% throttle the car would bog down massively and start to backfire it was that bad on the way back I made the mistake of going down the bank and had to go back up it I couldn't take the car out of first to second with out it falling flat out it's face and sounding like a AK47 is behind me ended up going back up the hill around 3k rpm about 15 mph and the car wouldn't push past that without just bucking ans backfiring .
Could do with any sort of advice the car is completly bone stock 93 import apart from a cat delete at some point in it's life.
it's had a full engine rebuild with the rats nest fully replaced out for new solinoids and vacuum lines .
I've also replaced the fuel tank and pump/filter for new .
Tried with completly fresh sparks .
I've Smoke tested the system through the UIM from the line that goes to the master cylinder not found anything from that.
Any advice would be great , im so close to finally enjoying this car
