- Jan 8, 2018
I have water coming in on the passenger side foot well.
No air con fitted so little pipe on the passenger side not leaking or the heater not leaking.
Water only comes in when raining heavy, and I like to drive it at weekends even in the winter so this is a pain in the arse.
The two drain points on either side front that you can see from above seem to be working, is there any other front drain pipes under
there somewhere hiding that could be blocked that I can not see ?
I hosed it down with a lot of water during the week and today there is water inside but I can not see where it is coming from. any thoughts.
