I recently had to disassemble my rear end to get new bearings in and replace some broken studs. My main issue arose when pulling the rear hub flange assembly off the drive axle. The small joint with the ABS sensor wheel also pulled off of the axle as it was fused with rust to the flange assembly. So once this had been removed I was left with what is pictured below and a bare rear drive axle.
So I am need to mate this with the rear drive axle.
However when I'm going to re-install this part onto the drive axle it wont go on past this retaining ring at the end the of the axle.
I'm think the ring may need replacing but I'm struggling to find one listed online, or am I missing a specific technique to getting it back onto the axle? It goes on about half an inch but wont go on any further and won't come back off.
