Stock Shock Heights
Nite_Shayde
Hello all,
Can anyone here tell me what the heights of the stock shocks are? The dimension from the upper surface of the upper mounts to the a-arm bolt holes is what I'm after on both the fronts and rears.
I have a set of coilovers with me that are only partially threaded; I'd like to work out how much they'll drop the car exactly :)
wont that be dependant on the spring length and stiffness, rather than the length of the shock body?
And if the shock is 30mm shorter it's sat at a variable angle so it doesn't mean it drops the car by 30mm would be 20 or something
