G Gunnytron Well-known member Joined Apr 7, 2018 Messages 397 Jan 26, 2021 #1 Has anyone fitted and NRG short hub style steering adapter? Are you supposed to remove or disassemble the stock clock spring assembly.
Liamc111 Well-known member Joined Jan 12, 2018 Messages 152 Jan 26, 2021 #2 Stock clock spring is removed and the lip around the cowling needs grinding off
G Gunnytron Well-known member Joined Apr 7, 2018 Messages 397 Jan 26, 2021 #3 Thanks. So what goes against the brass disc on the back of the hub? I assume it's meant for the horn button?
Liamc111 Well-known member Joined Jan 12, 2018 Messages 152 Jan 27, 2021 #4 Correct. You either need to modify a hair clip to push into the horn wiring on the main loom and touch the brass disc or live without a horn. I chose option 2
