Short hub install questions
Gunnytron
Has anyone fitted and NRG short hub style steering adapter?
Are you supposed to remove or disassemble the stock clock spring assembly.
Thanks. So what goes against the brass disc on the back of the hub? I assume it's meant for the horn button?
Correct. You either need to modify a hair clip to push into the horn wiring on the main loom and touch the brass disc or live without a horn. I chose option 2 🤣
