injector sizing
drifter1982
hello all how do i work out what size injectors are required.
i will be running
bridge ported 13b
hks t51r hks 60mm WG
all supporting mods
power fc
also i am looking for 500-550 bhp
Also i am ideally looking for an in tank fuel pump what would people advise Aeromotive, Walbro, Bosch
If anybody could show me how to work out the following that would be brilliant. i would like to know how to work it out as oppose to someone saying you need 1000CC AND 200OCC ETC
Many thanks appreciate all your help comments
lee
http://wannaspeed.com/content/6-fuel-system-calculator
850 primaries and 1680 secondaries are a very common fuel setup and according to the above are good for 672bhp. This is based on 45psi base fuel pressure, 14psi boost pressure, 85% duty.
As for fuel pumps, Walbro GST450 will pretty much drop straight in and will flow more than enough fuel. Downside is they pull a fair bit of current and are quite noisy.
Hello there thanks you for your reply. I had a good read up on the walbro and I have have heard good things so this is an option.
As per the injectors I was thinking 850 and 1680s as a few forums have suggested this setup.
Thanks for the link that explains it better.
