FEED style intank anti-slosh baffle tanks group buy
Stix44
Hi,
*Update- Julian has confirmed these will be £125+p&p if you want to secure your baffle please contact Julian directly on +44 7920 401794. You will need to bank transfer a deposit of £35 to secure your place*
Following a discussion in the RX7ribe whatsapp group it was suggested that someone post up here.
If we can get enough people together Julian is going to make a batch of FEED style intank anti-slosh baffle tanks, Julian previously sold these on the FDUK forum.
Here is what the finished product looks like:
The minimum number to place an order is 5 but the more people interested the better. The estimated lead time once the order is placed is around 6 weeks.
The price is currently estimated around the £120 mark but Julian is going to work out a more exact price including any volume discounts soon.
the current list is:
1. Stix
2. David H
3. Andrew 'Welshkid'
4. Sturneyrx7
5. JE96
6. Macer
7. Jack
8. Ste_Collins94
9. BenLewisMAV
10. hy_cupcakes
11. SchuKingR
12.
13.
14.
15.
If your interested just reply to this thread an I will add you to the list.
thanks
Stix.
How are these secured?
The pump hanger holds it in place. You only need to remove the level float and mount it on the baffle tank then its a drop in. They do take a little fiddling with the pump sock to ensure it doesnt prevent the flap from fully opening but its nothing difficult. Also because i have the 044 which is slightly larger, i adjusted the mounting for a nice flush fit when its all bolted down. Oh and remember to earth it just as a pre-caution.
There was a decent fitting thread ( Joe) but was possibly lost on fduk.
I've got an 044 also. I did wonder if my fuel.sock would fit.
Once the tank is in the fuel tank, the hanger holds it in place. It seems counterintuitive but there’s no way the FEED tank can move from its spot. It’s a bit weird to get in though, I had to put both tanks in and then install the fuel level sensor after the tank was in. I use a walbro 450 pump with no problems
