Drakes
MKZ7212
About to order some bits from Drake.
just wondered if anyone else wanted bits. He said he doesn’t really hold stock but can make stuff in 2-3 weeks
Yep! I'm after a dual vent pod in 52mm flavour:
Me too.
Ill be after a Map lid
Ok will keep this open until Friday then speak to drake about the order and see if we can get any discount etc. I can then get shipping and item cost and will have to let you know about any added tax when they get to the uk (worked out as a percentage) if that all sounds fair to everyone?
I wouldn't mind some stuff but isn't he behind on production?
I tried getting in touch with him recently, but no luck. Not sure if he's still just super busy these days? Would like a 2x60mm A-pillar pod (in RHD fitment, of course). I wouldn't need the usual post processing/finishing done to this since I want to wrap it in alcantara, which should lower the price, but if it makes things overly complicated then no bother
Hi there,
Could you see if he has one of these available please ?
Mark
Received the dbw kit from him - very good quality but got absolutely killed on import charges - didn’t realise he was back up as was planning on order some bits so this is good timing !
I’d take a centre speaker delete, meter hood clips, centre vent pod duo and the centre pod both in 52mm if we are doing a group buy
Well I want the full interior plastics OEM style and meter hood. But that will make it longer than 1-2 weeks
This order is growing Mark!
I'm not sure of he is making the bigger items or not at the moment as he may have a shortage on material.
I have ordered from him recently, a twin 52mm center vent gauge pod which was showing as in stock on the website. Place the order on the 14th of July and it was shipped on the 14th of August. A large bulk order may take more than 1-2 weeks.
Surely you just buy more materials?
I probably nagged him to death and he thought feck off, materials come from China, he also had issues with internet access as he used online software and had kack connection in the sticks.
but again hassled him and he probably thought feck ya, bought carbon dash off Angry panda in the end,
just to summarise so far, please check and or amend if something isn't right
1/ jack.am 52mm dual vent pod (https://www.draklore.com/shop/fd-center-vent-pod)
2/ hy_cupcakes Map lid
3/ Fiddy Map lid
4/ Davey Sileighty 52mm Dual vent pod (https://www.draklore.com/shop/fd-double-dash)
5/ Nite_Shayde 60mm Dual A Pillar (https://www.draklore.com/shop/fd-a-pillar)
6/ Francob Radio delete (https://www.draklore.com/shop/fd-radio-delete)
7/ west-wot Centre speaker delete / Meter hood clips / 52mm dual vent pod (https://www.draklore.com/shop/fd-center-vent-pod) / 52mm Dual vent pod (https://www.draklore.com/shop/fd-double-dash)
8/ JoeLanger Meterhood (https://www.draklore.com/shop/fd3s-meterhood) And anything else?
9/ x9wfm Map lid
Just spoke to Shane and he is going to coming back on what can or can’t happen. He has already said no to the meterhood and a pillar so unfortunately I will have to remove these
If you check his website anything that shows as available he can do. Anything out of stock is a no go.
1/@ jack.am 52mm dual vent pod (https://www.draklore.com/shop/fd-center-vent-pod)
2/ @hy_cupcakes Map lid
3/ @Fiddy Map lid
4/ @Davey Sileighty 52mm Dual vent pod (https://www.draklore.com/shop/fd-double-dash)
5/@ Francob Radio delete (https://www.draklore.com/shop/fd-radio-delete)
6/@ west-wot Centre speaker delete / Meter hood clips / 52mm dual vent pod (https://www.draklore.com/shop/fd-center-vent-pod) / 52mm Dual vent pod (https://www.draklore.com/shop/fd-double-dash)
7/@ JoeLanger Anything else?
8/ @x9wfm Map lid
