With my full rebuild with new bearings I'll just let it idle for 20-30 mins while I check pressures, temps, levels and for leaks. Then take it for a gentle shakedown drive to ensure all is in order then it'll be straight into boost. I really don't understand the run in superstitions with rotaries. If everything is clearanced correctly it just works. The bearings wear in within minutes. I'll do an earlier than normal oil change as I don't really want bits of bearings floating around for longer than nessisary, otherwise it'll be business as usual.
I build my own motors so that's fine for me. If yours is being built by someone else, follow whatever they advise to preserve your warranty.
