- Jun 17, 2020
Hi,
There may be a thread on this, but the search engine removes 'ABS' from the query string, so I cannot find one..
I found my ABS is no longer operating, though I have no idea when it failed. I do not recall it triggering in the ten years I have owned the car. I have been told that ABS failure results in poorer brake performance on rx7 due to lower brake pressure (or something like this, I cannot remember) and my braking distance has increased significantly so this seems to hold true. Can anyone verify this please?
I have seen ABS replacement/removal kits has anyone got experience of these, both fitting and running?
Is an ABS fix quite niche i.e. rotary specialist only, or will most performance garages be able to achieve this?
