Testing fuel pressure regulator
Nickmms94
Where is the best place to tap into the fuel lines to check regulated pressure ?
New too FD’s so any help apreiciated
I read the manual and it says about running the car with the relay out to remove the pressure but ive taken the car apart is there another way to relive the pressure as I don't fancy putting the manifold back on to take apart again lol
The return line wouldn't have the same pressure as what's on the rails though :unsure:
surely the feed?
Joe sounds right, its the pressure at the rail yoi need to check, the return should be near 0
No there isn't really.
Thanks guys, got around 40psi so guess the regulators fine need to get the injectors out to see if they are leaking.
