Obviously make sure you remove the circlip first.
Instead on bolts just use stud bar with nuts, any size you want then.
I had to soak mine in WD for a week then they cam out no problem with the nut and bolt method. The WD just breaks down the rust.
I had more difficulty getting them back in I couldn't get them lined up square again, had to use a press for that
So. I literally had the reverse of this - took the arm to the press over the road, and the midle ball bit of the bearing pushed through leaving the sleave - which is the same diameter as the lip so no chance of finding a draught/socket (and yes I used the biggest socket that would fit inside the lip a 24mm was perfect)
Hacksawed the sleave and then had to hammer the shite out of it to get it out.
Then the new pillow ball literally FELL into the arm, like no force at all.
Why why why lol It fought me every step of the way out, then soooo easy in lol.. Oh well at least it's done. I made a video of it going in as it was such a joke, but can't seem to up load it..
Also can anyone identify what type of pillow ball came out? It's nothing like the OEM Mazda and not like the J-auto ones either. It's a massive ball and race/sleave with spacers either side..
See how chewed up the sleave is from hammering lol..
