Oil pressure sensors
tomCTR
What you using guys?!..
Need one and not sure whether to risk an eBay jobbie one for 15 sheets 😂😂👍🏻
stock oilcooler bolt on pedestal drilled and taped 1/8npt and ebay oil pressure sensor. 150psi 0-5v fed into adaptronic works a treat. fuel pressure using same sensor
Ah the eBay king.. 👍 for £15 gotta be worth a go.. I have a mocal sandwich plates with 1/8NPT port on it, just has a bung in I think from memory so just stick in in there, new loom goes back to link ecu, then dash 2 will display the reading
Yay 😄
